It is currently Wed Aug 20, 2025 3:03 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
PostPosted: Mon Feb 24, 2014 6:37 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
okay a few questions here:
1. How did you get the green fibre strips in there? Did you use a teflon insert or some such thing?
2. I'm not familiar with the "weld on" glue. It must be some kind of contact cement no?
3. what kind of tape did you use for binding? It looks like that could rip out some of the top wood when you take it off. I am always fearful of really strong tapes in this situation.
Please forgive my ignorance.
These users thanked the author nickton for the post: ZekeM (Mon Feb 24, 2014 7:11 pm)
PostPosted: Mon Feb 24, 2014 7:15 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Im in the "less is more" category. Not a fan of a lot of bling and such. I prefer the understated with the small details really bringing things together. But im always impressed by the talent it takes to create such complicated schemes
PostPosted: Mon Feb 24, 2014 7:59 pm
Last Name: Kincheloe
I've been working on stuff for my two harp ukes, which have been pretty much stalled for the past few months due to extreme cold and dryness. Rosettes are all done, now just need to do Timberwolf's harp arm headstock (which will be the inverse of the split face neck headstock), and possibly add my standard abalone D logo above the tree on this one:
This one will have a side port in place of the harp arm soundhole, so I put a huge MOP moon in the usual spot :)
PostPosted: Mon Feb 24, 2014 8:59 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Dennis,
nothing routine about your work. Love the wolf!!!
PostPosted: Tue Feb 25, 2014 7:08 am
Hi all,
Here are a couple of pix of a rosette I recently made for a flamenco guitar commission. I really like this design, but it was a bear to get aligned.
Max Bishop
Brighton, Michigan
These users thanked the author MaxBishop for the post: Haans (Tue Feb 25, 2014 7:38 am)
PostPosted: Tue Feb 25, 2014 7:38 am
Hey, we are all ignorant, so no apology necessary. [:Y:]
I have the "ladder" strips made for me by Gurian, they are a Larson pattern. You can buy green sheet veneers from LMI though and cut your own strips.
You see a teflon strip in there for the green abalone (the green fibre strip makes it look sorta green).
Weldon 16 is the glue I use. It is similar to Duco cement, but I think it has some contact properties to it also. You can google it and find 5 oz tubes.
The tape is strapping tape and is pretty dang sticky. You don't rip it off, but you start at the end and "roll" it off. It is VERY strong and you can really pull it, but it doesn't stretch. I use .090" ivoroid binding and you really need to pull tape on that stuff.
PostPosted: Tue Feb 25, 2014 7:58 am
+1 on the strapping Tape! So much better for bindings than masking tape!
PostPosted: Tue Feb 25, 2014 8:12 am
I'm working on one where I took a bunch of left over bits from other builds and made decorative pieces. Going to be on the back strip, the end graft, and the rosette.
The woods are Granadillo, Maple, Mahogany, Monketpod, Bloodwood, Sycamore and Rosewood
Here's a shot of the back:
PostPosted: Tue Feb 25, 2014 2:07 pm
Last Name: Beaver
City: Lake Forest
You guys are good!!!
Joe Beaver
Maker of Sawdust
PostPosted: Tue Feb 25, 2014 2:13 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Max,
those classical rosettes are some of the best I've seen!!! [clap] [clap]
Neil,
What a neat way to dress up the back - adds some extra color to the maple. [clap] [clap]
PostPosted: Tue Feb 25, 2014 2:20 pm
DennisK wrote:
I've been working on stuff...
Dennis, I like how you used the natural twig shapes. Might have to steal it! :)
PostPosted: Tue Feb 25, 2014 5:51 pm
Do it! So many lovely bits of wood just going to waste rotting on the ground :)
These users thanked the author DennisK for the post: Pmaj7 (Tue Feb 25, 2014 6:19 pm)
PostPosted: Tue Feb 25, 2014 6:15 pm
Martin,
Thanks for the comment. The design of the central mosaic was made by Robert Ruck. I told him I would give him credit if I showed it anywhere.
Max
Max Bishop
Brighton, Michigan
PostPosted: Wed Feb 26, 2014 11:20 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Just following on from my previous post, here's the first rosette finished:
Pablo Picasso
PostPosted: Thu Feb 27, 2014 2:01 pm
Wow those mosaic rosettes (and backstrips by the look of it) are really en vogue - just gorgeous stuff >everyone!!
clap clap clap clappity clap
cheers
charliewood
PostPosted: Thu Feb 27, 2014 2:07 pm
First name: neil
Last Name: mchardy
City: Carlisle
State: Cumbria
Zip/Postal Code: CA4 8QQ
Country: United Kingdom
That is absolutely megga. I love the idea of the mosaic, do you use some form of backing behind it?
PostPosted: Fri Feb 28, 2014 8:11 am
What I do is thickness all the pieces to the same thickness and then cut them into shapes. Then I fit and glue them up on a flat surface covered with waxed paper. I put a black strip between.
To put it into the back I used my router to cut an inlay channel and then glued it in.
PostPosted: Tue Mar 04, 2014 9:15 am
Finally finished the GC-6 BRW project and it is ready for final sanding and finishing.
Users browsing this forum: Brad Goodman and 32 guests
